  3. How to get test name from test session object?
  • Views 15401
alexstepanov75
alexstepanov75 over 6 years ago
I have a test session object that I am getting like this:
maeTstSession=maeGetTestSession(test ?session session)
Is it possible to get the test name from this object? I am asking because this object passed to several levels of functions and I don't want to pass an additional argument with the test name
    Doesn't appear to be possible with a public function (I didn't really check if a private function exists though). If you are passing the session too (not necessary if you've only opened or are dealing with a single maestro session), then you would do:
    maeTstName=car(exists(testName maeGetSetup(?typeName "tests" ?session session) maeGetTestSession(testName ?session session)==maeTstSession))
    If  you only have a single maestro session, you can omit the ?session session parts from the above expression.
