  3. customizing status toolbar
  • Views 15718
jaivarsha
jaivarsha over 6 years ago
I would like to add items like length of selected metal or area also in status tool bar. I have tried below option but I am getting warning as shown below. Could you please give suggestions.
envGetVal("layout" "statusToolbarFields")
*WARNING* envGetVal: Could not find variable 'statusToolbarFields' in tool[.partition] 'layout'
Varsha
    Hi Varsha,
    You need to be using IC618 or ICADVM181 ISR9 or later, which presumably you are not. This env var and control is a fairly new feature...
  • jaivarsha
    jaivarsha over 6 years ago in reply to Andrew Beckett
    Thank you for the quick reply. When I do getVersion() I see IC6.1.8-64b.500.8 as the version
    Varsha
    Andrew Beckett over 6 years ago in reply to jaivarsha
    Hi Varsha,
    OK, so you're one subversion too old to access this.
