  3. How can I make a SKILL procedure not callable?
  • Views 15143
Byron Caloz
Byron Caloz over 6 years ago
Inside the scope of isCallable there is code which I don't want to be executed.
The procedure named in isCallable to-day is callable.
I want to make that procedure so it cannot be called.  How do I do that?
I can't change the isCallable line or the scope.  I want to change its behavior by making sure that the procedure does not exist (obviously this would be done before the code is executed).
    Andrew Beckett over 6 years ago +1
    I think you're just asking how to undefined a function? Assuming it's a SKILL function (i.e. implemented in SKILL) and not a Cadence built-in function implemented in C, you can do: putd('myFunc nil)…
    putd('myFunc nil)
    note that if there is an autoload property to cause the code to be auto-loaded when called, you'd also need to reset that (otherwise it remains callable):
    remprop('myFunc 'autoload)
    Does that help?
  • Byron Caloz
    Byron Caloz over 6 years ago in reply to Andrew Beckett
    Yes, that is very helpful.  Turns out, though, that it was a Cadence built-in function, so won't be able to take this approach.
