  3. Select all members of a constraint with SKILL
  • Views 14993
RVERP
RVERP over 6 years ago
I want to select a constraint, and then run a SKILL command that returns a list with the members of that constraint. Is this possible?
Thx,
    There are various cst and ci SKILL functions that can retrieve constraints and then access the members (either via a function or by looking at attributes of the object using ~>?? to see available attribute/value pairs). Did you try those?
  • RVERP
    RVERP over 6 years ago in reply to Andrew Beckett
    I didn't really knew were to start looking. The info I needed I found in geGetEditCellView()~>constraintGroups~>owner~>members
    Thanks for the help.
