  3. How to get m0 layer info in a layout
  • Views 16389
EJAZ27
EJAZ27 over 6 years ago
HI All,
I am new to skill. My requirement is
open layout
get m0 layer cordinates in a layout
dump info into a text file
For example 2 input Nand, A,B output , vcc , vssx and internal net (n2) will be the m0 layers. I need info like in a text file.
n2 co ordinate
vssx (co ordinate)
a (co ordinate)
b (co ordinate ) .
I found similar code in cadence form . Can you help me on this
 procedure(printPts()
let(    (type
    (cnt 0)
    (objList geGetSelSet()))
foreach(obj objList
    ++cnt
    type = obj~>objType
    case(type
        ("inst"
            printf("%s %L at %L\n" type obj~>xy))
        ("rect"
            printf("%s on layer %L at %L\n" type obj~>lpp obj~>bBox))
        ("polygon"
            printf("%s on layer %L at %L\n" type obj~>lpp obj~>points))
        ("path"
        ("pathSeg"
            printf("%s on layer %L at %L\n" type obj~>lpp list(obj~>beginPt obj~>endPt)))
        ("label"
            printf("%s on layer %L at %L\n" type obj~>lpp obj~>xy))
        (t    printf("%s not defined\n" type))
printf("%n objects selected\n" cnt)
); end of let
); end of printPts
    Andrew Beckett over 6 years ago +1
    First of all, was the layout created with Layout XL? If not, it probably won't have connectivity information, and so you're unlikely to achieve your goal. If it was, you can find the net name by looking…
  • EJAZ27
    Hi All,
    I like to get the netname and coordintes of all Metal0 drawing present in the layout which is opened to be written in a text file as output
    First of all, was the layout created with Layout XL? If not, it probably won't have connectivity information, and so you're  unlikely to achieve your goal. If it was, you can find the net name by looking at obj~>net~>name (in code similar to that which you posted). Rather than operating on the selected objects, you could  do something like:
    cv=geGetEditCellView()
    M0drawing=car(exists(lpp cv~>lpps lpp~>layerName=="M0" && lpp~>purpose=="drawing"))
    foreach(obj M0drawing~>shapes
    I don't know what you want in terms of "coordinate". For a path or a polygon do you want all the points? For a rectangle do you wan the bounding box?
    Your requirements are pretty vague... so I can't write code for you. So hopefully the above will get you started in at least roughly the right direction.
  • EJAZ27
    EJAZ27 over 6 years ago in reply to Andrew Beckett
    What I mean by co ordinate is x,y centre of the polygon. Even xh and yh of Bbox is fine
    Layout is opened in the XL mode also
    Can I get the netname of shapes/polygon also
    Thanks in advance
    Andrew Beckett over 6 years ago in reply to EJAZ27
    Something like this:
    outFile=outfile("./report.txt")
    M0drawing=car(exists(lpp cv~>lpps lpp~>layerName=="m0" && lpp~>purpose=="drawing"))  ; make sure you have the right layer name here
      when(obj~>net
        fprintf(outFile "%s %L\n" obj~>net~>name centerBox(obj~>bBox))
    close(outFile)
  • EJAZ27
    Thanks alot for the quick response. I will try it out
    Ejaz Mirzan
