  3. ddDeleteObj() and its warnings
  • Views 18935
Aldo2
Aldo2 over 6 years ago
After deleting cells using the following loop:
foreach(cellId ddGetObj(libName)~>cells
    ddDeleteObj(cellId)
the following warnings are printed in the CIW:
*WARNING* (SCH-2162): "... symbol" has been updated since "... schematic" was last saved. Validate that the schematic is correct and run Check and Save to suppress this warning.
*WARNING* (DB-270337): dbGetInstHeaderMaster: Failed to open cellview '...' from library '...' in read-only mode because the cellview does not exist. This cellview was instantiated in cellview '...' of library '...'. Ensure that the cellview exists in the library.
Is it possible to turn them off?
Thank you
Best regards,
Aldo
    I can't really see why ddDeleteObj should be causing sch or db warnings, unless there's some triggers in place (maybe as part of a design management integration?) to do some checks? I'm guessing here - but there's certainly no specific way with ddDeleteObj to deal with these warnings.
    In current versions you have the muffleWarnings() construct that you could surround your code with to swallow any warnings. muffleWarnings was introduced in IC618/ICADVM181 ISR1.
  • Aldo2
    Aldo2 over 6 years ago in reply to Andrew Beckett
    Thank you Andrew.
    Unfortunately, I am using IC616 and so I cannot use muffleWarnings(). I tried also to disable the design management sw, but I continue having warnings.
    Best regards,
    Aldo
    Andrew Beckett over 6 years ago in reply to Aldo2
    Hi Aldo you could use the CCFcaptureWarnings macro or this code if you don't care about capturing the warnings in a variable:
    /* abMuteWarnings.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 31, 2018
    Modified
    By
    A macro to mute the output from anything sent to woport (warnings).
    Based on abMute (written many years ago)
    abMuteWarnings(warn("test this\n") warn(""))
    will produce nothing.
    Relies on SKILL's dynamic scoping, so will not work in SKILL++
    unless you do:
    inSkill(abMuteWarnings(warn("test this\n") warn("")))
    SCCS Info: @(#) abMuteWarnings.il 12/31/18.11:36:17 1.1
    (defmacro abMuteWarnings (@rest body)
      `(progn
         (unless (openportp (getqq abMuteWarnings nullport))
           (putpropqq abMuteWarnings (outfile "/dev/null") nullport))
         (let ((woport (getqq abMuteWarnings nullport)))
           ,@body
    You can then just use:
        abMuteWarnings(ddDeleteObj(cellId))
  • Aldo2
    Thank you, Andrew. It works.
    Just a clarification: Lint sees woport variable as unused. Is it possible to have "clean" Lint report?
    Thank you
    Best regards,
    Aldo
    I don't see woport reported just by using these macros, but I can see the you might get it if you have something like this:
    let(((nullport outfile("/dev/null")))
      let(((woport nullport))
        warn("this")
        warn("that")
        getWarn()
    I think the only way to suppress the message is to do:
    skIgnoreMessage("Unused")
    but that will suppress all unused variables. I don't believe there's a more selective way of ignoring specific variables. Of course, you could cheat by doing:
        ; reference to a variable just to get clean Lint score
        woport
        warn("this")
        warn("that")
        getWarn()
    Personally I don't like doing that - I'd sooner just document the reasons for a score being lower.
