  3. User defined LSW order
  • Views 14716
psill000
psill000 over 6 years ago
Is there a way for a user to define the LSW order?
What layers are on the top portion of the LSW?
For example; to have the visible layers at the top of the list.
Paul
    Paul,
    You can click the column headings for layer and purpose and it sorts based on those, but by default it doesn't sort the V or S column (click there toggles on/off). So instead if you can bring up the palette options form (e.g. right mouse over where it says "Search" or "Active" or "Layer Set", pick Options, and change the "Header Column Click" to "sort". Then you can click on the header of the V or S column and sort by visibility or selectability.
