  3. Reliability analysis
  • Views 15359
alexstepanov75
alexstepanov75 over 6 years ago
I checked manuals but I am unable to find function to work with "Reliability analysis" in Assembler.
Is it possible from SKILL to create and configure "Reliability analysis" setup, or, at least, check if "Reliability analysis" enabled in the current Assembler session?
    Andrew Beckett over 6 years ago +1
    You should contact customer support - I don't think this is possible right now. There was an older "relx" API but that was really intended for ADE L and doesn't work well with the way that reliability…
    You should contact customer support - I don't think this is possible right now. There was an older "relx" API but that was really intended for ADE L and doesn't work well with the way that reliability analyses are set up in Assembler. I found an existing enhancement change request, CCR 2187191 asking for this - please mention this when you contact customer support.
