  3. Best way to get list and manipulate Stimulus Files using...
  • Views 14657
Best way to get list and manipulate Stimulus Files using SKILL in Assembler
alexstepanov75
alexstepanov75 over 6 years ago
I need to add a stimulus file to a test in Assembler. So first I want to get a list of stimulus files, check if the file already exists, and add it if not.
I am currently using
sevSession = axlGetToolSession(session testName)
o_session = asiGetSession(sevSession)
asiGetEnvOptionVal(o_session 'stimulusFile )
I am getting list of files, but don't getting status of checkbox that enables/disables this file.
So how can I get also status of the checkbox?
When I adding file I am using a similar approach and asiSetEnvOptionVal(o_session 'stimulusFile stimulusFilesList)
This has the same problem. Because I am not adding a file but setting all the list, I am unable to properly set status of checkboxes for each one.
Is it a better way to do this with the possibility of setting checkbox status?
THanks!
    Andrew Beckett over 6 years ago +1
    You need to also set/get 'allStimulusFiles which is a list of lists, with the first entry being a t/nil and the second being the file. You have to set both so they are consistent (the UI does this for…
    You need to also set/get 'allStimulusFiles which is a list of lists, with the first entry being a t/nil and the second being the file. You have to set both so they are consistent (the UI does this for you). stimulusFile is the list of enabled files, and allStimulusFiles is the list containing both enabled and disabled files with their status.
