  3. Get hierarchical shape net names for the current cellvi...
  • Views 18141
Get hierarchical shape net names for the current cellview
TobiasMrks
TobiasMrks over 6 years ago
How to get the net name of an Instance with Skill in Virtuoso Layout in the context of the current cellview?
I tried
instance->master->shapes
Then select a shape and readout:
shape->net->name
But now the net name is in context of the instance or Pcell instance and not the net name corresponding in the cellview.
Is there a way to get the in the cellview given connectivity for a shape inside an instance or pcell?
Thank you for your responses
    Andrew Beckett over 6 years ago in reply to TobiasMrks +1
    Well, it depends on whether the shape has got connectivity or not - many shapes inside PCells will not have connectivity - typically only the pins have connectivity. Assuming the shape does have connectivity…
  • mbracht
    mbracht over 6 years ago in reply to TobiasMrks +1
    master = instance->master (foreach mapcar instTerm instance->instTerms (list instTerm~>name (setof shape master~>shapes shape~>net~>name==instTerm~>term~>net~>name)) )
  • mbracht
    There is not "one" single net an instance is on - an instance is usually connected to more than just one net - here's how you get at the net names:
    instance->instTerms~>net~>name
  • TobiasMrks
    TobiasMrks over 6 years ago in reply to mbracht
    Ok, but is there a way to get the corresponding net name from a shape inside the instance?
    Well, it depends on whether the shape has got connectivity or not - many shapes inside PCells will not have connectivity - typically only the pins have connectivity. Assuming the shape does have connectivity, you're only going to get the higher level net name if it's actually a shape on the same net as the terminal (terminal is the logical, pin is the physical). So for a shape inside the PCell, knowing shape~>net~>terminal~>name, and then if you looked over instance~>instTerms~>name for the same terminal name, you could look at the instance~>instTerms~>net~>name to find the corresponding net at the level above.
    Sorry if that was a bit poorly described - it's hard to know precisely what you're doing in terms of processing the design.
  • mbracht
  • TobiasMrks
    TobiasMrks over 6 years ago in reply to Andrew Beckett
    That is exactly what I was going for.
    Thank you.
