  3. How to Load the Forms items/Menus automatically by text...
  • Views 5739
How to Load the Forms items/Menus automatically by text file (using load button on form) in skill !!!
Sonu Chopra
Sonu Chopra over 6 years ago
Hello Everyone,
I have a query regarding the loading of skill forms items/Menu's automatically . As in some of tools the forms items can be loaded automatically by text file (usually called runset file & it stored the value of all the form items),
Can we do the similar thing in skill too ? Can we save the skill form items/Menus in a text file or in some other way and load it later on (using load button in form itself) .
For Example :
I am explaining the above query with an example : In the Below Form I want to load the items/Menu based on the text file (run set file) which stored the values of all the form items.
Can you please provide some help on this how we can do this?
Regards
Sonu
    Andrew Beckett over 6 years ago +1
    You'd have to write code specific to your form to do this. See this example which has an option to save/load a template for inspiration . Andrew.
    You'd have to write code specific to your form to do this. See this example which has an option to save/load a template for inspiration.
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for the quick response & for sharing the examples to load/save template . I will try at my end and let you know in case if any help is needed.
    Thanks for all the help Slight smile
    Regards
    Sonu
  • Sonu Chopra
    Sonu Chopra over 5 years ago in reply to Andrew Beckett
    Hello Andrew,
    I am posting my query in my existing thread as query is completely related to it (So I didn't have to add the information again).
    I was able to Load/Save the Runset by clicking the Load/Save Button and its working Perfectly Fine. Thanks for help for the last time.
    Now , We Want to go 1 first further in automation by loading all the Runset files for all forms automatically through a script without any user invention (No Need of Clicking of Load for loading the Runset and OK/Apply
    Button for Form Callback).for that we are adding additional parameter in Runset File Such as Form Symbol to Display the Form and Access it Fields
     I Tried to solve this problem by 2 Approaches but I  am Facing a lot of issues and not able to solve or understand how its can be done :-
    1. Blocking Nature of Form :- Blocking Nature of Form is by Default and to avoid this we have set ?dontBlock argument as t which immediately return t after hiDisplayForm Command otherwise it was not executing
    below remaining code . But As we set this ?dontBlock t and if I use hiCurrentForm() in my script now it return nil which means i am not able to access form now or its out of Focus. Can you please confirm this Point ?
    2. Storing Form Symbol Name in Runset File :- As we have form Symbol in Runset File so I used get function  to Extract form Symbol and then applying ~> or -> Field Parameters which even Doesn't Work.
    For Example :-  Form Symbol is Stored As an Additional List as disembodied property List
    Runset File Contents :
    RunsetParameter = '( 'Paramters_List
    library_Name_Gen "DTK_Qacells_Lib"
    library_Name_Dg "DTK_Qacells_Lib"
    width_Gen 0.8
    length_Gen 0.9
    grid_Gen 0.005
    x_Ref_Gen 1.0
    y_Ref_Gen -4.0
    x_Ref_Testcase 5.0
    y_Ref_Testcase 5.0
    tolerance 1.0
    loc_Enc_Layer1 0.01
    loc_Enc_Layer2 0.01
    overwrite_Qacell "Yes"
    RunsetAddParameter = '( 'Add_Paramters_List
    form_Name general_Var_Form
     Script to Load Form Automatically with Issues Highlighted :- I am facing issues in the Following Line as shown Below .Can you Suggest Something on This ?
    if(General_Runset_File != nil then
    load(strcat(runset_Path car(General_Runset_File)))
    hiDisplayForm(get(RunsetAddParameter "form_Name"))
    Form_Str = get(RunsetAddParameter "form_Name")
    Form_Str~>fieldList  --------------------------------------------------------------> Doesn't Work and Return Nil
    or get(RunsetAddParameter "form_Name")~>fieldList ----------------------> Doesn't Work and Return Nil
     loadi(strcat(getShellEnvVar("DTKROOT") "/skill/Skill_DUV_Scripts/Load_Template_Function.il"))
    hiFormDone(Form_Str)
    Regards
    Sonu
    Andrew Beckett over 5 years ago in reply to Sonu Chopra
    Sonu,
    It's going to involve too much guess work to try to figure out how you've defined your code, what is going on and so on. I rather doubt it's necessary to display the forms in order to initialise them.
    My suggestion is that you contact customer support for this, and provide all the code, rather than hoping that somebody will be able to read between the lines and guess what implementation decisions you've made so far from just a few selected pieces of information. I certainly can't guess (or rather it's going to be a load of work to try to figure out what you've done here from what you've said).
  • Sonu Chopra
    Hello Andrew,
    I agree with you i will contact customer support with details info as you mentioned.
    Just one point if you have any suggestion/Advice on this point
    can you we please suggest how i can load the Form without Displaying them ?
    As my Load Procedure invovle hiGetCurrentForm() to make it generic for all form . If I will not Display them then hiGetCurrentForm() will return nil ?
    There is any other way to do that ?
    Regards
    Sonu
    If your load procedure is defined as:
    procedure(MyLoadTemplate(form)
       ; use the form argument passed in to interact with the form
    Then from the button on the form you can call MyLoadTemplate(hiGetCurrentForm()), but when called procedurally, you can call MyLoadTemplate(get(RunsetAddParameter "form_Name")) .
    You might also need to use hiInstantiateForm() after creating the form with hiCreateAppForm etc, if you're trying to interact with the form but you've not displayed it yet - it depends on what you're doing (this is sometimes necessary). That builds all the UI structures, but doesn't actually display it.
