  3. Reading points from external script; data limit for ipcReadProcess...
  • Views 15201
Reading points from external script; data limit for ipcReadProcess?
patschouly
patschouly over 6 years ago
I'm using ipc* functions to read points for a polygon (layout) from an external script. This works fine, however fails for larger amount of points. I can't boil it down to an exact number (however, it's not the 4000-polygon limit, it's before dbCreatePolygon). What could cause this and how could I solve this? Can I read line-by-line from the script?
Here is what I'm doing (the points are separated by semicolons):
 let(
            pid str pts
        pid = ipcBeginProcess("lua /path/to/script.lua")
        ipcWait(pid)
        str = ipcReadProcess(pid)
        foreach(elem parseString(str ";")
            pts = cons(evalstring(elem) pts)
        dbCreatePolygon(geGetEditCellView() list("QB" "drawing") pts)
    Generally I would recommend that anything that needs to generate a lot of data and send via IPC, that you redirect the output to a file and then read the file. There have been long-standing issues with IPC (unfortunately never resolved) where the buffers overflow and you can lose data if lots of data is output.
  • patschouly
    patschouly over 6 years ago in reply to Andrew Beckett
    Ok, thanks for the insight. I'm now reading from a file, which works perfectly. Thank you for your fast reply.
