  3. map/apply a list to a function with multiple arguments
  • Views 6918
ZoltanT
ZoltanT over 6 years ago
Hello everybody,
I would like to obtain a list by substituting an argument of a multiple argument function with elements of a list.
Example:
procedure(foo(a b) a+b)
foo
mapcar('foo(1) 'list(1 2 3))
*Error* mapcar: not a function - (foo 1)
It works if the function has only one argument, but how should I proceed if the function has multiple arguments? Shall I define another procedure where I reduce the number of arguments to only one? Or just build the desired list in a foreach loop element-wise? I do not have a good feeling what would be the "skill-ed" way to accomplish this and I would like to hone my SKILL knowledge a bit.
Thanks!
Zoltan
  • skillUser
    skillUser over 6 years ago
    Hi Zoltan,
    You can supply multiple lists for mapcar so that each successive pair is taken from the two lists, for example:
    mapcar('foo '(1 2 3) '(1 1 1))  ; but this could be tedious, so:
    mapcar('foo '(1 2 3 4 5) ciUtilsRepeatNTimes(1 5))
    => (2 3 4 5 6)
    If 'foo' had three arguments you would make three lists and so on.  Generally speaking though, when I encounter this I refactor the code using foreach, e.g.
    foreach(mapcar input list(1 2 3)
      foo(input 1) ; assuming '1' is a fixed argument in this context
    => (2 3 4)
    This can make for better code readability too, and generally would be easier to understand for most folks.
    Hopefully this helps explain mapcar better?
    Best regards,
    Lawrence.
    Andrew Beckett over 6 years ago in reply to skillUser
    If you really want to just use mapcar directly, the pattern that Lawrence shows using foreach mapcar is equivalent to doing:
    mapcar(lambda((input) foo(input 1)) list(1 2 3))
    In essence, it creates an anonymous function which takes one argument (which calls your original function with two arguments) and passes that to mapcar. The foreach(mapcar ...) form is a macro that generates the mapcar above.
  • ZoltanT
    ZoltanT over 6 years ago in reply to Andrew Beckett
    Thanks for both of you!
