  3. [SKILL++] get the list of instances of a Class
  • Views 15539
GiuseppeGreco
GiuseppeGreco over 6 years ago
is there a way to retrieve the list of instances of a Class?
Le'ts suppose:
defclass( A() ())
i1 = makeInstance('A)
i2 = makeInstance('A)
How can I get the object defined in i1 and i2 without using support variables?
Best regards,
Giuseppe
    Hi Giuseppe,
    I don't believe there is any function to do this. You could write an initializeInstance method to collect a list of all instances as they are allocated, but the problem with doing this is that it would prevent garbage collection of the objects. So not a good idea.
    Why would you need to do this?
  • GiuseppeGreco
    GiuseppeGreco over 6 years ago in reply to Andrew Beckett
    Hello Andrew,
    actually, as you suggest,  now I'm collecting instances in a list and manage it in a proper way. I was curios to understand if it was there an alternative way to do that. There is not a specific need behind this request, I'm just trying to learn something about Skll++..
    As usual, thank you for your fast feedback!  :-)
    Giuseppe
