  3. Adding Pass/Fail criteria at axlOutputResult ocean output...
  • Views 4498
Adding Pass/Fail criteria at axlOutputResult ocean output expression
oyayla
oyayla over 6 years ago
I am adding ocean output expressions to the Adexl with axlAddOutputs() and axlOutputResult(). I am wondering if there is a way to add also pass/fail criteria to these expressions.
yayla
    Andrew Beckett over 6 years ago +1
    Hi Yayla, No, you cannot add spec limits from within the OCEAN script measurement. There is a SKILL function to add spec limits to outputs, axlAddSpecToOutput, but it is not designed to be used within…
    Hi Yayla,
    No, you cannot add spec limits from within the OCEAN script measurement. There is a SKILL function to add spec limits to outputs, axlAddSpecToOutput, but it is not designed to be used within an OCEAN script measurement.
  • oyayla
    oyayla over 6 years ago in reply to Andrew Beckett
    Thanks Andrew for the quick reply.
  • oyayla
    Is there a way to export the derived output experissions? If I can, I process them and reload to the Adexl even if it is cumbersome. I have tried to use "axlOutputsExportToFile" but getting below message. I believe loading back the derived outputs will have the similar issue
    WARNING (ADEXL-2038): Output "piOut_slewF_ph270" has not been written to the CSV file 'ACoutputs.csv' because ADE XL does not support export of "derived" outputs.
    yayla
