  3. PDK Environment Checking unsuccessfully
  • Subscribers 152
  • Views 17551
Woodhouse
Woodhouse over 6 years ago
I followed PDK user initialize project setup by following steps:
copy display.drf, .cdsinit, cds.lib. assura_tech.lib, setup.loc, and pdk.csh from the PDK install directory to the design project process.
And then do
setenv PDK_INST_DIR /home/project
setenv CDS_TECH
setenv THICHNESS
setenv MIM_TECH
setenv HR_TECH
setenv SHRINK_TECH
setenv MOM_MODELE_PATH/MOM_TECH_NAME/MOM_INCLUDE_PATH
ln -s <PDK directory>/Models
ln -s <PDK directory>/Stream
and finally, source the PDK shell script by
source pdk.csh
However, when I try to open schematic, it shows PDK environment checking unsuccessfully.
and ask me to check 1. Install and configure Keysight Momentum&ADS properly; 2. Copy 'set.loc' and '.csdinit' from PDK install directory to your working directory.
I did copy them in the first step of initializing project setup.
Wood.
    Hi Wood,
    This is something specific to the PDK you're using (or it's something in the Keysight setup?). It's certainly nothing that Cadence tools are doing out of the box, so you'd need to check with the PDK provider for more details.
  • freidadavi5
    freidadavi5 over 6 years ago
    Hi buddy, which version you are using as of now would you mind telling? That would help find out solution faster.
    Sloth Smith
