  3. Variable by itself on a line: meaning?
  • Views 16404
Proto
Proto over 6 years ago
Dear SKILL experts,
I am going through a SKILL code written by another person, and I noticed a few instances in which there was a variable by itself on the entire line of code. Initially, I thought this was the way to return a value in a function, but there is a return() construct, so that may not be it. Is it simply a syntax mishap or is there a valid purpose behind it? If it's the latter, could you please kindly explain what it is?
Kind regards,
Proto
  • skillUser
    skillUser over 6 years ago +1
    Hi Proto, Yes, the variable on its own line, if it is the last thing in a let, procedure etc. will return the value of that variable from that block (procedure, let, progn, ...). The return() statement…
  • skillUser
    Hi Proto,
    Yes, the variable on its own line, if it is the last thing in a let, procedure etc. will return the value of that variable from that block (procedure, let, progn, ...).  The return() statement is for the prog() construct. Note also that some programming constructs have useful return values, such as 'case' and 'cond', but others are not so useful (e.g. 'for' and 'foreach' unless it is used with another construct like 'mapcar'). I do not personally like 'prog-return' blocks as it can be difficult to work out the flow of control with arbitrary exits in the middle of the prog code block.
    Best regards,
    Lawrence.
  • Proto
    Proto over 6 years ago in reply to skillUser
    Hi Lawrence,
    Thank you for your detailed explanation -- it makes sense now. I am fairly experienced with different programming languages (C/C++, Python, Tcl), but SKILL is just something else. It has some unusual syntax that still confuses the heck out of me Astonished
    Cheers,
    Proto
    Andrew Beckett over 6 years ago in reply to Proto
    Hi Proto,
    SKILL is essentially a LISP underneath - it just has some alternative input syntax to make the code look more C-like by allowing infix operators - so that you can use (for example):
    a=a+2*3
    rather than:
    (setq a (plus a (times 2 3)))
    (both work in SKILL though and are entirely equivalent). One key principle to understand in SKILL is that everything is a function (so every operator, everything you call, corresponds to a function) and all functions have a return value, whether you use it or not. Because of that, there is a principle in most expressions that the return value is the last thing computed - so the return value of a let() is the last thing computed, as is the return value of a procedure(). There are a few exceptions to this, such as prog() which returns nil unless you call the return() function within to indicate the return value, but I'm less keep on arbitrary jumps out of the middle of a block of code because it's harder to follow, as Lawrence said (it's "spaghetti programming").
    You might want to take a look at my video: Writing Good SKILL Code (Video)
    By the way, LISP is one of the oldest high level languages, and whilst old has been quite innovative over the years and has influenced a lot of other languages (there are quite a few concepts in Python that originate from LISP, for example).
    So yes, I agree - it's quite different from C/C++, Python and Tcl, but then again Python and Tcl are quite different from C/C++ too!
