  3. sort association table by values
  • Views 17221
Genas
Genas over 6 years ago
I know you can sort association table by keys (keys=sort(myTable->? 'alphalessp) but i want to sort by values.
Because the values are numerical. For example i want the table below to be sorted numerically by the values.
MyTable["C"] = 5
MyTable["A"] = 5.5
MyTable["B"] = 3
should be
MyTable["A"] = 5.5
MyTable["C"] = 5
MyTable["B"] = 3
Can anyone assist with the skill code to achieve this?
    Andrew Beckett over 6 years ago +1
    keys=mapcar('car sort(tableToList(MyTable) lambda((a b) cadr(a)>cadr(b)))) (assuming you wanted them in decreasing numerical order, as you showed above - if you wanted them in increasing order, change…
    (assuming you wanted them in decreasing numerical order, as you showed above - if you wanted them in increasing order, change the > to be a <).
    Breaking this down:
    • tableToList(MyTable) converts the table into an association list, i.e. (("B" 3) ("C" 5) ("A" 5.5))
    • The lambda is an anonymous function of two arguments, that compares the cadr (second element) of each list. So given ("B" 3) and ("A" 5.5) it would be comparing the 3 and 5.5
    • The sort returns the sorted association list
    • The final mapcar('car ...) applies the car function to each sublist and hence returns the first of these, i.e. the keys in the order you want.
  • Genas
    Genas over 6 years ago in reply to Andrew Beckett
    Thanks, that solved my problem. I never knew there was a table to list function.
    Thanks for the assistance
