  3. How to map a docked form to layout/schematic?
  • Views 3482
gopalk07
gopalk07 over 6 years ago
I have designed a main form having buttons for bunch of scripts. Each button opens up another form (script's form) to receive user inputs and then performs the operation in layout/schematic.
So, in order to avoid floating of multiple forms, i created  both the main form and the  script's form as docked windows into a session window.
But the issue is script's form is now not mapped to the layout/schematic window, instead it treats the docked window  as current window.
How could I map the docked script's form to perform operation in layout/schematic?
Thanks for your help.
I have referenced the below solution for creating the docked form in window.
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSaaEAE
    It's unclear what you've implemented and what you're asking. I initially thought you'd added a docked window to your layout/schematic window, but it sounds as if you have created a separate session window with docked windows within, and you want hiGetCurrentWindow() to still refer to the separate layout/schematic window? If so, you can do so by having your new window (with the form) marked as neverCurrentWindow. ie. windowId~>neverCurrentWindow=t . Note that if you do that, any callbacks you have within your new form window can't use hiGetCurrentWindow() to refer to themselves - you'd probably need to build the callbacks as you're building the form and window so that they are something like:
    sprintf(nil "doSomething(window(%d))" windowId~>windowNum)
    Sorry if this doesn't make sense, but I'm having to do an awful lot of guesswork as you've not clearly explained what you've done and what you expect. If you'd provided  your code, that might have made it easier, ideally with enough data to understand your expected use model.
  • gopalk07
    gopalk07 over 6 years ago in reply to Andrew Beckett
    Thank you for your reponse.
    After making the new window as neverCurrentWindow, I am able to get the desired output.
    But I am having difficulty in building the callbacks to refer to current window. For example, hiCloseWindow function requires current window ID. As hiGetCurrentWindow() couldn't be used, I have used the session window ID. I have made Session window ID as global variable. Is my approach right? If not, would you please explain the process to build callback using the below example code.
    Thanks again.
    procedure( createMainWindow()
    let((win1 dock_main )
    swin_exampleGUI = hiCreateWindow(nil "session" "Container Window")
    hiCreatePulldownMenu(
    'mainWindowMenu
    "&File"
    list(
    hiCreateMenuItem(
    ?name 'close
    ?itemText "&Close"
    ?callback "hiCloseWindow(swin_exampleGUI)"
    hiInsertBannerMenu( swin_exampleGUI mainWindowMenu 1)
    unless(boundp('mainForm)
    createMainForm()
    win1 = hiCreateWindow(nil "text" "Example Window")
    dock_main = hiCreateDockWindow(
    ?appType "Main Form GUI"
    ?widgetType "form"
    ?handle 'mainFormGUI
    ?form mainForm
    ?title "Main Form"
    hiDockWindow(
    ?window dock_main
    ?session swin_exampleGUI
    ?side 'left
    hiDisplayWindow( win1 swin_exampleGUI)
    win1 -> neverCurrentWindow = t
    procedure( createMainForm()
    let((goToXYButton)
    goToXYButton = hiCreateButton(
    ?name 'goTo_button
    ?buttonText "Go To"
    ?callback "goToXY()"
    hiCreateAppForm(
    ?name 'mainForm
    ?formTitle "Main form"
    ?fields list(
    list(goToXYButton 10:200 100:30)
    mainForm
    procedure( goToXY()
    let( ( point zoomLevel dock_goToXY)
    point = ""
    zoomLevel = ""
    point = hiCreateStringField(
    ?name 'point
    ?prompt "Enter X,Y"
    ?value point
    zoomLevel = hiCreateStringField(
    ?name 'zoomLevel
    ?prompt "Zoom Level"
    ?value zoomLevel
    ?defValue "100"
    applyButton = hiCreateButton(
    ?name 'applyButton
    ?buttonText "Apply"
    ?callback "goToXYProc()"
    goToXYForm = hiCreateAppForm(
    ?name 'goToXYForm
    ?formTitle "Go To XY"
    ?initialSize t
    ?fields list(
    list(point 10:0 300:40 100 )
    list(zoomLevel 10:30 150:40 100 )
    list(applyButton 10:70 40:25 )
    ;hiDisplayForm(goToXYForm)
    dock_goToXY = hiCreateDockWindow(
    ?appType "goToXy Window"
    ?widgetType "form"
    ?handle 'win_goToXY
    ?dockSizeHint list(350 100)
    ?form goToXYForm
    ?title "Go To"
    hiDockWindow(
    ?window dock_goToXY
    ?side 'right
    procedure( goToXYProc()
    let( (xValue yValue convertPoint)
    if(goToXYForm->point->value ==""
    then
    hiModalDBoxHelp("Enter Correct X and Y Values")
    else
    xValue = nil
    yValue = nil
    xValue = car(parseString(goToXYForm->point->value ",") )
    yValue = cadr(parseString(goToXYForm->point->value ",") )
    hiPan(hiGetCurrentWindow() list(aelNumber(xValue) aelNumber(yValue)))
    hiZoomRelativeScale(hiGetCurrentWindow() aelNumber(goToXYForm->zoomLevel->value) )
    convertPoint = geWindowToEditPoint(hiGetCurrentWindow() list(aelNumber(xValue) aelNumber(yValue)))
    leSetRefPoint(geGetEditCellView() convertPoint)
    leMoveCursorToRefPoint()
