  3. Skill script to add prefix to existing pins on schemati...
  • Views 17349
Skill script to add prefix to existing pins on schematic
TommasoF
TommasoF over 6 years ago
Hi all,
I would need to take all the pins placed on an existing schematic and rename them by adding a prefix (or suffix). I navigated throughout the various threads of the forum and tried out several different solutions, but somehow they do not serve my need. I tried to write a script on my own, but I am a newbie on SKILL so it's not so easy...
Can somebody give me a hint on how to do that ?
thanks
Tommaso
    Andrew Beckett over 6 years ago +1
    Hi Tommaso, Simply renaming the pins (probably terminals is what you really mean) is simple: cv=geGetEditCellView() foreach(term cv~>terminals term~>name=strcat("PRE_" term~>name)) However, in practice…
    Hi Tommaso,
    However, in practice you also need to fix the wire labels too, and that can get a bit more complicated if you have bus/bundle wire names (I'm not going to write the code to do that). Assuming it's just simple wire names, something like this could do the job:
    prefix="PRE_"
      ; rename simple wire labels
      foreach(fig term~>net~>figs
        when(fig~>objType=="label" && fig~>theLabel==term~>name
          fig~>theLabel=strcat(prefix fig~>theLabel)
      ; rename the terminals
      term~>name=strcat(prefix term~>name)
    ; re-extract connectivity
    schCheck(cv)
  • TommasoF
    TommasoF over 6 years ago in reply to Andrew Beckett
    thank you very much, that works perfectly!
    Tommaso
