  3. Turnoff grid dots in layout view
  • Subscribers 150
  • Views 18640
mattab
mattab over 6 years ago
There is a line in my cdsenv which turn on the layout dots automatically.How to turn it off?
layout dotsOn Boolean nil
    That option is to control dot pins, not to control the display of dotted grids (oh, and Boolean should be boolean). There are three options that affect this:
    layout drawDottedGridOn boolean t
    layout drawGridOn boolean t
    layout dotStyleMajorGrid boolean nil
    With these two as t (the default) then dot grids will be drawn. If you change the first to nil, then it will do line grids. If you turn the second off, no grid will be drawn. The third option makes a difference if the first two are on (i.e. you have dot grids) and if set to t, it dims the major grid dots so they are not so bold.
  • mattab
    mattab over 6 years ago in reply to Andrew Beckett
    Thanks Andrew!
