  3. pass argument to enterPoints procedure
  • Views 19115
mantang
mantang over 6 years ago
Hi
How do I pass extra arguments "theForm" and "instances" of CCSbtnFld1CB to addPointProc and doneProc ?  (w done pts) or (w plist) are default argument. The example in SKILL manual does not show the solution.
inst_sel = hiCreateButton(
      ?name concat('inst_sel i)
    ; ?buttonText "Select instances from the schematic"
    ?buttonText "Select"
  ; ?callback "CCSbtnFld1CB(hiGetCurrentForm())"
  ; ?callback list("CCSbtnFld1CB(hiGetCurrentForm() i)")
    ?callback list(
         sprintf(nil
         "CCSbtnFld1CB(hiGetCurrentForm() 'instances%d)"
          i
procedure(CCSbtnFld1CB(theForm instances)
   let( ()
     enterPoints(
     ?prompts list("Click to select instances in the cellview. Press Esc key when done with selections")
    ?addPointProc "CCSAddPtCB"
    ?doneProc "CCSPointsDone"
     );enterPoints
);let
);procedure
procedure( CCSPointsDone( w done pts)
unless( done
   get(ExampleForm instances)->value = buildString(
      setof(obj geGetSelSet()
      and(obj~>objType=="inst"
      obj~>purpose!="pin"))~>name)
);unless
t
);procedure
procedure( CCSAddPtCB( w ptlist )
geSelectPoint(w car(last(ptlist)))
);procedure
ManChak
  • mbracht
    mbracht over 6 years ago
    Hi Mantang,
    The answer is simple - you can't. Those callbacks defined in enterPoints(..) are always called with exactly those three respectively two arguments. That's why yo get an error when you don't implement them expecting just these arguments. So to get at the current form you'll have to issue hiGetCurrentForm(..) and geGetWindowCellView()~>instances and assign the return values to local variables.
    Max
  • mbracht
    oops - I made in a mistkae in my earlier post. With geGetWindowCellView()~>instances you get all the cell view's instances. To get the selected ones only you need to
    (setof fig (geGetSelectedSet (geGetWindowCellView)) fig~>objType=="inst")
  • mantang
    mantang over 6 years ago in reply to mbracht
    Hi mbracht
    Thank you for your info. Your previous message said return local variable. How do I  assign the return value of CCSPointsDone  to variable inside CCSbtnFld1CB ?  Please see the bold line.
    Everyone: Any suggestion ? Thank you for your help  in advance
        let( ()
                 enterPoints( ?prompts list("Click to select instances in the cellview. Press Esc key when done with selections")
                 ?doneProc "CCSPointsDone"     ;  how do I assign the return value of CCSDPointDone heree
                 );enterPoints
        );let
    );procedure
    prog(str1
         str1 = ""
        unless( done str1 = buildString( setof(obj geGetSelSet() and(obj~>objType=="inst" obj~>purpose!="pin"))~>name)
        );unless
        return str1 ) ; proj
    );procedure
    );procedure
    Andrew Beckett over 6 years ago in reply to mantang
    Unfortunately this is one of those things that would be a whole lot easier if the various enterFunctions (enterPoints, enterBox etc) allowed the callbacks to be specified as a function object rather than a string (CCR 2169313 is asking for this - you might want to contact customer support and request a duplicate) as then you could use a SKILL++ closure to share variables between the calling function and the callbacks. I do have a hideous workaround for that, but it's so ugly I don't want to share it in public as I wouldn't really want people relying on it.
    Anyway, in this specific case, the easiest approach is to not use the doneProc but rely on the return value of enterPoints. Note that often in the schematic and layout editor the "Repeat Commands" editor option is on, and that prevents the enterPoints from returning - it calls it again afterwards. So we need to temporarily turn that off. See the code below for an illustration how to do this - based on your example somewhat:
    procedure( CCFAddPtCB( w ptlist )
    procedure(CCFdoEnterPoints(instances)
      let((points modalCommands str1 application)
        ; temporarily turn off "repeat commands" so that the
        ; function returns after one run. Don't bother with the doneProc
        ; but use the return value instead
        application=case(geGetEditCellView()~>cellViewType
          ("schematic" "schematic")
          ("schematicSymbol" "schematic")
          ("maskLayout" "layout")
        modalCommands=envGetVal(application "modalCommands")
        ; the first block is the code to invoke, and the second block
        ; is guaranteed to run even if there is an error in the first block
        ; or it is aborted for some reason
        unwindProtect(
            envSetVal(application "modalCommands" 'boolean nil)
            points=enterPoints(
              ?addPointProc "CCFAddPtCB"
            when(points
              str1 = buildString(setof(obj geGetSelSet() and(obj~>objType=="inst" obj~>purpose!="pin"))~>name)
            printf("str1 is %L\n" str1)
          ; make sure that the modalCommands is reset afterwards
            envSetVal(application "modalCommands" 'boolean modalCommands)
  • mantang
    mantang over 6 years ago in reply to Andrew Beckett
    HI Andrew,
    Thank you for your code.
    ManChak
