  3. Finding overlapping shapes/instances over instances
  • Views 5562
skillUserD
skillUserD over 6 years ago
Hello.
I am in the need to find and mark shapes/instances that are overlapping instances within a cell view in Virtuoso.
I am using the code below which is taken from Cadence support. The code successfully recognizes instances overlap, but not shapes (polygons, path, pathSegs, etc) that are overlapping instances. I am using ICADVM18.1-64.
Any advice would be greatly appreciated.
Danny
procedure(CCScreateOverlapArea(dst src)
let((llAx llBx llAy llBy urAx urBx urAy urBy boxLL boxUR )
                llAx = xCoord( lowerLeft( dst ))
                llBx = xCoord( lowerLeft( src ))
                llAy = yCoord( lowerLeft( dst ))
                llBy = yCoord( lowerLeft( src ))
                urAx = xCoord( upperRight( dst ))
                urBx = xCoord( upperRight( src ))
                urAy = yCoord( upperRight( dst ))
                urBy = yCoord( upperRight( src ))
                boxLL = max( llAx llBx ):max( llAy llBy )
                boxUR = min( urAx urBx ):min( urAy urBy )
                list( boxLL boxUR )
);let
);proc
procedure(CCScheckInstOverlap( @optional (cv geGetEditCellView()))
let(( visited dinstList dbox sbox overlap ignoreCellList)
ignoreCellList=list("abc" "sealring" "mycell")
foreach(sinst cv~>instances
        unless(member(sinst~>cellName ignoreCellList)
        dinstList=dbGetOverlaps(cv dbTransformBBox(sinst~>master~>prBoundary~>bBox list(sinst~>xy sinst~>orient)) nil )
                foreach(dinst dinstList
                        when(dinst~>objType=="inst" && dinst~>name != sinst~>name && !member(dinst~>cellName ignoreCellList) && !member(dinst visited)
                        dbox=dbTransformBBox(dinst~>master~>prBoundary~>bBox list(dinst~>xy dinst~>orient) )
                        sbox=dbTransformBBox(sinst~>master~>prBoundary~>bBox list(sinst~>xy sinst~>orient) )
                        overlap=CCScreateOverlapArea(dbox sbox)
                        unless(abs(caar(overlap) - caadr(overlap)) < 1e-6 || abs(cadar(overlap) - cadadr(overlap)) < 1e-6
                                dbCreateMarker(cv sprintf(nil "Instance %s overlaps with instance %s" dinst~>name sinst~>name) "CCS"
                                                 list(car(overlap) list(caadr(overlap) cadar(overlap)) cadr(overlap)
                                                 list(caar(overlap) cadadr(overlap))) nil t t "warning" "overlap"
                         printf("Instance %s overlaps with instance %s \n" dinst~>name sinst~>name)
                visited=cons(sinst visited)
                );unless
        );foreach
        t
);let
);proc
