  3. SKILL Lists
  • Views 19479
SKILL Lists
Leonardo Vinci
Leonardo Vinci over 6 years ago
List_Original=
((x1, y1) (x2 y2))
((x3 y3) (x4 y4))
((x5 y5) (x6 y6))
List_Original is a list of coordinates.
I want to copy this list and make changes to the new copy(say, List_A) while preserving List_Original. The change what i want to do is +/- the y-coordinates by 0.5, I do it as follows:
List_A=nil
List_A=List_Original
foreach(val List_A
a=cadr(nth(0 val)) + 0.5
b=cadr(nth(1 val)) - 0.5
cadr(nth(0 val))=a
cadr(nth(1 val))=b
Now the problem coming is List_A is not getting updated and is remaining same as List_Original. Why is that? I am not getting any error or warning in code.
I even checked the variables "a" and "b" and they are getting updated as I wanted, but List_A is not getting updated and is the same as List_Original.
Please tell me what am i doing wrong?
Leo
  • AurelBuche
    AurelBuche over 6 years ago +1
    Hi Leonardo, You are doing two things wrong: 1. if you do: List_Original ='( ((0 1) (2 3) ) ) and List_A = List_Original then List_A and List_Original will point to the same object, if you modify…
    Andrew Beckett over 6 years ago in reply to AurelBuche +1
    I would do it this way, which is much more immune to side effects: List_A=foreach(mapcar bBox List_Original list( xCoord(lowerLeft(bBox)):yCoord(lowerLeft(bBox))+0.5 xCoord(upperRight(bBox)):yCoord…
  • AurelBuche
    AurelBuche over 6 years ago in reply to Andrew Beckett +1
    My bad, you're definitely right, the foreach mapcar approach is much more robust and natural (even though the foreach mappings might not be obvious for users experienced with other languages) Thanks…
  • AurelBuche
    Hi Leonardo,
    1. if you do:
    List_Original='(
                              ((0 1)  (2 3))
    and
    then List_A and List_Original will point to the same object, if you modify one it means you modify the other one
    You will have to store a copy version in order to do whatever suits you:
    List_A = (copy List_Original)
    2. you cannot use = with a function call on the left side:
    you can use setf to achieve what you want:
    (setf cadr(nth(0 val))  cadr(nth(0 val)) + 0.5)
    should work
    I really don't like the combined use of both cadr and nth (those are two ways of doing the same thing, I think you should stick to one)
    In your case, you can use topEdge (bottomEdge, leftEdge or rightEdge works as well)
    Your final code should look like this:
    (foreach bbox List_A
      (setf (bottomEdge bbox) (bottomEdge bbox)+.5)
      (setf (topEdge bbox)       (topEdge bbox)+.5)
    Cheers,
    Aurel
        list(
            xCoord(upperRight(bBox)):yCoord(upperRight(bBox))-0.5
    Unfortunately Aurel, your approach still destructively modifies the original list. That's because copy() doesn't do a deep copy - it only generates a new top-level list, and your destructive operations are one level down.
  • AurelBuche
    My bad,
    Thanks for your rectification
    Cheers,
    Aurel
  • Leonardo Vinci
    Leonardo Vinci over 6 years ago in reply to AurelBuche
    Hi Aurel, and  Andrew Beckett
    = is an assignment operator, so the value of variable on RHS is assigned to the value of variable in LHS. Then why after I change the variable on LHS, which is List_A, when i do the foreach, is not reflected? Since the code runs serially, the latest foreach loop should update the values of List_A right?
    Please correct me.
    Leo.
    Andrew Beckett over 6 years ago in reply to Leonardo Vinci
    Leo,
    You can assign to a variable, but you cannot assign to the result of a function - that is not a variable. So when you were doing:
    cadr(nth(0 val))=a
    that will not work. You could use setf() to do this kind of assignment, but then you'd be modifying the original list, which you explicitly said you don't want to do.
