  3. User Triggers for Layout L and Layout XL using deRegUserTriggers...
  • Views 16034
User Triggers for Layout L and Layout XL using deRegUserTriggers Command !!
Sonu Chopra
Sonu Chopra over 6 years ago
Hello Everyone,
I need your help regarding understanding of user triggers for Layout L & Layout XL using deRegUserTriggers Command .
Currently i am duplicating this command in my code to have same user triggers for layout Menu in Layout L & Layout Xl . Is it the correct way to do it  ? Can we trigger it for both Layout L & Layout Xl using a single Command?
I am not facing any issue as per now but just to now what is is the correct way to do it .
For Example -
deRegUserTriggers("maskLayoutXL" nil 'DuvToolKitMenuInLayout)
deRegUserTriggers("maskLayout" nil 'DuvToolKitMenuInLayout)
Regards
Sonu
  • skillUser
    skillUser over 6 years ago +1
    Hi Sonu, I think this is correct - you need to register the trigger per viewType and so each Tier has a different viewType (e.g. L, XL, GXL, EXL). I do this in a foreach loop in my code, something like…
  • skillUser
    Hi Sonu,
    I think this is correct - you need to register the trigger per viewType and so each Tier has a different viewType (e.g. L, XL, GXL, EXL). I do this in a foreach loop in my code, something like the following for you then:
    foreach(layoutTier list("maskLayout" "maskLayoutXL" "maskLayoutEXL" "maskLayoutGXL")
      when(member(layoutTier deGetAllViewTypes())
        deRegUserTriggers(layoutTier nil 'DuvToolKitMenuInLayout)
      ); when
    ); foreach
    Best regards,
    Lawrence.
  • Sonu Chopra
    Sonu Chopra over 6 years ago in reply to skillUser
    Thanks Lawrence for the confirmation . Thanks for attaching the code for each layout Applications ( Layout L , Layout XL , Layout GXL etc.)
    Regards
    Sonu
