  3. Have corners' sweep and temperature sweep corners be auto...
  • Views 2737
Have corners' sweep and temperature sweep corners be auto-populated in maestro.
LDIL
LDIL over 6 years ago
Hello all.
Let us say that I have a set of corners, for functionality.
I want to have a group of them already set (although by default disabled, and only the typical corner run), so that the user can just select them, for running process corners and voltage.
It would be best if this is something that the user cannot easily edit, like the default corner in maestro now.
I could not find a way to have this setup, so that each new Maetsro view will have this auto-populated.
Thanks.
