  3. Rotate instance by 45 degree
  • Views 20799
Will Tang
Will Tang over 6 years ago
Dear all,
How could I rotate a instance by 45 degree?
It seems there is no way to do this.
Any comment is much appreciated.
Thank you very much !!
Will
    Will,
    There's no direct way, but there's a possible workaround. First of all, is this in a schematic or layout? Is the thing you want to rotate a fixed layout, or a PCell (e.g. a transistor layout - I'd be surprised if it's a transistor). Does the object you wish to rotate by other angles contain a lot of shapes?
  • Will Tang
    Will Tang over 6 years ago in reply to Andrew Beckett
    Yes, the PCell is a layout PAD which contains 4 layers of shapes.
    Would it be possible to rotate it by 45 degree?
    Will
    Andrew Beckett over 6 years ago in reply to Will Tang
    Will,
    I'm not sure your PAD cell is really a PCell (is it parameterised such that the layout changes as you change the parameters?), but even so this will work with PCells as well as fixed layouts. Do:
    cv=dbOpenCellViewByType("yourLib" "PAD" "layout")  ; or whatever the lib/cell/view is called
    dbCreateXformPCell(cv "yourLib")  ; if "yourLib" is not writable, you can write into a different library
    If the component does not have CDF already, you can place an instance of yourLib/PAD/layout_xform (note the new viewName gets created) and you can specify the angle parameter on the instance to be whatever you want (e.g. 45). If the component does have CDF, you can either edit the CDF to add a new float parameter angle, or place an instance of the layout_xform view and then edit properties and add a user-defined property (on the properties tab in the edit properties form) called angle, type float, value 45.
