  3. How to get Pcell instance pins connection information?
  • Views 17852
GGLin
GGLin over 6 years ago
I create a cellview with a Pcell instnace.
And I want to attach the label according to the DGSB for LVS.
I can use the inst->master->terminals->pins to get the DGSB pins correspond coordinate in the cellview.
Like:
instParentTerminals = inst->master->terminals
foreach(term instParentTerminals
    foreach(pin term->pins
        printf("%L\n" pin->fig->lpp )
        pointList = tconc(pointList dbTransformPoint(centerBox(pin->fig->bBox) inst->transform ) )
    terminalList = tconc(terminalList list( term->name car(pointList) ) )
    pointList = nil
But I need to know which metal in the Pcell is connected to these pins due to the figs of these pins are not assigned to the metal directly. ex: S and D are assigned to OD
Is there any way to get this kind of information?
Or is there any way I can do net tracing in db level rather than open a window and call leMarkNet? It is not a efficient way to do such a thing.
    Are you sure there's no pin on the metal to? Often there is a pin (or pin figure) on both diffusion (OD) and metal so that when you connect in layout XL, you can route to the pin in metal. The metal pins may however get removed if you abut the devices (and the OD pins remain), so maybe that's what you're talking about?
    You could use dbGetOverlaps to find overlapping metal at the point where the OD pins exist (doing the dbGetOverlaps within the pCell submaster).
    By the way, I'm not sure why you have two nested loops over term->pins in your code. You could just have looked at pin~>fig~>app within the loop you already had.
  • GGLin
    Thanks for the replay.
    Yes I can see the /S/ /D/ /G/ on the pcell metal.
    But when I use the code above, only the G can get the metal pin, while S & D can get only the OD pins.
    and the nested code is just a paste error, I just want to see the layer name and purpose only.
    Andrew Beckett over 6 years ago in reply to GGLin
    OK, I've realised what you're probably doing wrong. Rather than looking at pin~>fig, you should look at pin~>figs. It's likely that the pin has multiple figures, which is how strongly connected pins are represented in the database. The ~>fig is a compatibility mode for old CDB code because prior to OpenAccess, you could only have a single figure on each pin and strong connects were represented a different way.
    So try iterating over the figs on the pin and see whether there's a figure on the layer you want.
  • GGLin
    GGLin over 6 years ago in reply to Andrew Beckett
    Thanks! It works.
