  3. The graph can follow the mouse movement function
  • Subscribers 150
  • Views 14941
yankunRen
yankunRen over 6 years ago
For example:
1. When creating Via, the preview image of Via can follow the mouse position to move.
2. When creating a Label, the Label will also move with the mouse.
When I use IC616, I want to create a Skill with the following functions,Graphics can follow the mouse movement,
But I don’t know this function. Which function is it?
yankun
    Assuming you are talking about using an enter function (e.g. enterPoint, enterPoints etc), then you only have limited control over what they draw. So for example, enterDonut, enterPolygon etc do (by default) draw a ghost outline based on the points you've entered, but you cannot show the contents of an instance or something else at the cursor point as part of these. Support for that is done at a much lower level and there's not (as far as I know) SKILL support to do the same.
    What exactly are you trying to do here?
