  3. performance multiple value vs multiple calls to value in...
  • Views 13793
performance multiple value vs multiple calls to value in ocean
LDIL
LDIL over 6 years ago
Hello all.
Let us say that I to loop over samples of waveform wf, starting from point x1, in x2 intervals (time domain).
final_t is the last time point.
This leaves us with two main options.
Either one does for( i 0 floor( (final_point-x1 )/x2 ) )
     y_val=value( wf x1+i*final_point )
;rest of code below.
Option 2 would be to create a samples waveform, and loop on its' elemnts:
wf_sampled = drGetWaveformYVec( values( wf x1 ?period x2 ) )
And then do:
for( i 0 sub1( len( wf_sampled ) )
    y_val=drGetElem( wf_sampled i )
 ; rest of code below.
The value of val should, IMHO, be the same for each iteration. If not, I may have a bug.
Assuming that RAM is not a limiting factor, should there be a significant performance difference?
I would suspect that this may be the case, if there will a lot of samples, and value always needs to re-access the psfxl file.
