  3. Retutning to previous selected results after using selectResults...
  • Views 15250
Retutning to previous selected results after using selectResults command
LDIL
LDIL over 6 years ago
Hello all.
I have an OCEAN script that would require me to use selectResults('instance)
However, I may want to perform afterwards commands such as value( IS( "/V1/PLUS"  0 ).
The results may be in tran, ac, dc, or some unknown, and I would like to have my command return to whatever results were already selected.
Is there a way of doing that?
    Andrew Beckett over 6 years ago +1
    You could do: currentResults=getResults()->name then after the operation, do: selectResult(currentResults) Andrew.
    You could do:
  • LDIL
    LDIL over 6 years ago in reply to Andrew Beckett
    Works like charm.
  • LDIL
    LDIL over 5 years ago in reply to Andrew Beckett
    Hi Andrew. I have one tiny correction. It should be getResult()->name and not getResults()->name
    It's probably a typo.
    Andrew Beckett over 5 years ago in reply to LDIL
    It was a deliberate mistake to check that you were paying attention!
    Yes, I probably just typed it in rather than pasting from a session where I'd tried it, so I made a mistake in the transcription.
