  3. Seeking Closest Lisp dialect to Skill (not Skill++)
  • Views 17484
rcs0
rcs0 over 6 years ago
I am interested what 'Custom IC Skill' readers consider the closest FOSS Linux compatible Lisp dialect to Skill? As the title states, I'm interested Skill, not Skill++. (1)
Why?
My company's Linux/Cadence environment is top notch. The windows loaded hardware, vpn, remote access software, passwords, and surveys required to enter that environment are prohibitive. I'd like to develop functions for coordinate number crunching, layer mapping, etc., in a Linux Lisp environment, and move debugged code to Cadence Skill.
"SKILL and SKILL++ are distinct dialects of LISP and are not either Scheme or Common Lisp or any of the others. They may share similar syntax to the other dialects, but they have different semantics." -- A. Beckett
I don't expect 100% compatibility. I'd like opinions on a good starting point-- e.g. Guile vs SBCL-- minimizing changes when moving to Skill. A Lisp expert colleague suggested (define)ing a familiar dialect to be Skill-like. I like that idea, though I'd like to pick a good starting point.
(1) 'Skill' seems more oft used than 'Skill++' in my area, so I'd like to stick with Skill. I prefer the CL coding style (setq a 0), so I'm not interested in procedural support (a=0).
Thank you for any guidance.
    I think you'll struggle to find a dialect that is especially close, partly because SKILL derives from Franz Lisp which has been discontinued for some time, and most common current LISPs are either based on ANSI Common Lisp or Scheme (yes, there are a few other flavours) - see the timeline of dialects on the Wikipedia page I just linked to. Also, SKILL has itself been extended quite a bit over the years, adding a number of features from a variety of other LISPs, including Common Lisp and Scheme, plus having functions inspired by C, Python, Pascal and numerous other languages. New data structures have been added in the language too (many of which have existed for 25- 30 years, but are not in Franz Lisp).
    I'm also unsure as to how valuable it would be, because you tend to soon move away from just using the core language to using the application programming interfaces to Virtuoso itself for example. I suspect you'd spend quite a lot of time emulating other functions and this is going to be quite a bit of effort.
    Whatever dialect you pick, you're going to have to do a fair bit of work to come up with a similar dialect, so it probably doesn't matter too much whether you start from SBCL, Racket or Guile. I guess it depends how much core language stuff you're going to be doing as to whether it's worthwhile.
    Note that more of SKILL++ is inspired by Scheme and Common Lisp so you might actually find writing for SKILL++ easier. There's generally no downside, as you can call existing SKILL functions from SKILL++, and SKILL++ has lexical scoping which is generally safer and less prone to errors.
  • RK56
    RK56 over 6 years ago in reply to Andrew Beckett
    Totally off-topic. Sorry for this.
    I wish Cadence had chosen TCL/Python as interface language. All the skills I have in SKILL is not much useful outside Cadence environment. I know these languages are younger compared to LISP but still...
    -Ramakrishnan
  • rcs0
    rcs0 over 6 years ago in reply to Andrew Beckett
    Thank you Andrew.
    This is the guidance I was hoping for. Time will tell if developing 'core language' helpers for API calls outside the vpn wall is more efficient. I'm pretty certain I excluded the use of SKILL++ prematurely, so thank you for that tip.
    A promising sign is I experimented by simply renaming a set of generic utils I include everywhere as 'stdlibs.il' to 'stdlibs.ils' and everything I tested ran successfully.
    Interestingly, the first time I ran the experiment I received the following error:
    *Error* eval: can't update SKILL function in Scheme via assignment
    I restarted the (very old) Virtuoso session, and from then on I can alternate between '*.il' code and '*.ils' with only a warning:
    *WARNING* (define): redefining SKILL function buildCoordList to be Scheme variable
    or
    *WARNING* (def): redefining Scheme variable buildCoordList to be SKILL function
    No new question-- just an observation. I appreciate your detailed response.
    Andrew Beckett over 6 years ago in reply to RK56
    We'd have needed a time machine, since these languages didn't exist when SKILL was first used in the Cadence tools.
    I do cover this to some extent in my Writing Good SKILL Code (Video) - to some extent, what matters most is the application interfaces you're using, and knowing how to program. The details of the language is  the simplest part to translate (obviously Python has a very large set of available open source extension libraries, which makes it particularly attractive though). However, legacy and years of code developed around Virtuoso is something you wouldn't be able to apply arbitrary libraries for other languages to those kinds of problems.
    So I understand the sentiment, but I think it's not so important in practice.
