  3. STIMULI control via ocean script
  • Views 15512
Genas
Genas over 6 years ago
I have an ocean script where I’m running a simulation and I want to set a value for one of the input stimuli (“trm_db”) but for some reason its not letting me do that, I am using this command to set the variable but when I check the maestro view stimuli GUI after running the simulation, I do not see this variable set to this value.
 ocnxlStimuliData(?inputs '(((name "trm_db") (nodes ("trm_db" "/gnd!")) (enabled t) (tranType "dc") (srcType "Voltage") (instParameters (dc("3v") type("dc"))))))
I guess I'm missing something
    The ocnxl function will only affect the OCEAN script. It will not update the settings in the Maestro view.
  • Genas
    Genas over 6 years ago in reply to Andrew Beckett
    Thanks for this information. Do you know of any method or option to update the settings in the Maestro view. I saw a solution on the cadence support but it requires opening the GUI to get the current form. I want any solution that doesnt involve opening the GUI, just updating the settings via skill.
       formId = hiGetCurrentForm()
        foreach(choice formId~>artStmBox~>choices
           formId->artStmBox->value = list(choice)
           formId->artStmEnabled->value = t
           formId->artStmTranType->value = "sin"
           formId->dc->value = "2"
           artStmChangeCB(formId)
        );foreach
    Also, (leveraging on this solution), is it possible to get the form ID without using hiGetCurrentForm()
    Andrew Beckett over 6 years ago in reply to Genas
    I'm not sure there's a public way at the moment. You should contact customer support, as there ought to be a "mae" function to do this.
  • Genas
    Thanks, I have contacted customer support
