  3. Print the X Y coordinates of the mouse click point in c...
  • Subscribers 150
  • Views 16675
Print the X Y coordinates of the mouse click point in ciw
Cadence Skill
Cadence Skill over 6 years ago
HI Sir,
 I wanted to X Y of the mouse click in the layout to  be printed in CIW window.
I tried with leHiShowCoord command , but I am not getting how print in CIW.
I searched in TechForms, but couldn't found.be printed i
Guru
  • skillUser
    skillUser over 6 years ago
    Hi Guru,
    Every mouse click in the layout is already recorded - take a look at the CDS.log file for each point as it is entered, with the command, for example:
    \a addPoint(hiGetCommandPoint())
    \i 0.2535:0.588
    \r t
    \r t
    \a hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9)
    \r t
    \a mouseSingleSelectPt()
    \i 0.137:1.101
    \r t
    If you really want to print every left-click in the CIW then you can change the bindkey setting for the left-mouse click operation, something like this:
        procedure(printPoint() printf("=> %L\n" hiGetCommandPoint()))
        hiSetBindKey("Layout" "None<Btn1Down>" "printPoint() mouseSingleSelectPt()")
        hiSetBindKey("Layout" "None<Btn1Down>EF" "printPoint() mouseAddPt()")
    You would also need to probably do the same for the Shift + left-click and other combinations.
    Hopefully this helps you.
    Lawrence.
  • Cadence Skill
    Cadence Skill over 6 years ago in reply to skillUser
    Thanks Lawrence Slight smile
