  3. automatic stack strace for errors.
  • Views 15457
LDIL
LDIL over 6 years ago
Hello all. Let's say that I run this code snippet:
procedure( ko(i ) bar( i*2 ) ) procedure( bar( j ) printf( "yo %d\n" ) ) ko( 2.3 )
I get:
*Error* fprintf/sprintf: too many format specs.
However, I need to look and see which procedure was calling  printf.
One could surround snippets of the code with error handling, and then issue an error, but this is, well, rather cumbersome.
I assume that some macro can be
Is there a way to have the stack-trace printed automatically when such error is issued, and/or get the line in the procedure which caused it, or number of step (in this case, 1, or 0, which number one wants to start counting).
    If you set this variable:
    _stacktrace=50
    Then you'll get a stack trace displayed when there is any error. Alternatively, if you have the SKILL Debugger enabled you can also choose to see local variables, the stack trace - most easily done through the SKILL IDE. It will even highlight the line in the code where the error occurred.
