  3. leZoomToSelSet doesn't work when opening a schematic
  • Views 2357
strotta
strotta over 6 years ago
Hi guys, I will really appreciate if someone give me a hand.
I have this simple test but I don't know why is not working as expected
        myCell = deOpenCellView(projName cellToOpen "schematic" "" hiGetSessionWindow(hiGetCurrentWindow()) "r")
        myInst=setof(x myCell~>cellView~>instances x~>cellName=="patternName")
        mapcar('geSelectFig myInst)
        leZoomToSelSet()
The idea is to open a schematic(cellToOpen) and find all the instances that match with "patternName". After that, I would like to zoom-in on the instance that was found (if it was just one).
If I run the code line by line it seems to work but I don't know why not when I run it in a row. It seems there is an automatic zoom-to-fit after leZoomToSelSet() call..not sure
Thanks!
  • mbracht
    mbracht over 6 years ago
    Just to be sure what you do - you have the cell projName/cellToOpen opened in a graphic window already (for example a layout editor) haven't you?
    I'am also not sure what you mean by "when I run it in a row" - are you saying you copy and paste the entire code  into the CIW or load it in terms of a load() statement. For me it works in both ways.
    I also don't understand why you use a layout function (leZoomToSelect) while you are in a schematic editor. You should use schHiZoomToSelSet() instead.
    Max
  • strotta
    strotta over 6 years ago in reply to mbracht
    No, that's reason why I'm using deOpenCellView. However, if I do this (window already open):
    myCell = geGetEditCellView()
    myInst=setof(x myCell~>instances x~>cellName=="patterName")
    leZoomToSelSet()    ;or schHiZoomToSelSet()
    code works fine. there is something wrong related to opening a new window.
    yes
    I also tried with schHiZoomToSelSet() but it didn't work
