  3. how to add a trigger when open/close a layout view
  • Views 4055
acom
acom over 6 years ago
For a layout cellview, we are going to add some function before opening the layout view and after closing the cellview.
When we tried to add the trigger before opening the layout view, it means after we double clicking the  cell view in the library manager before the virtuoso show up the layout view .
When we tired to add the trigger after closing the layout view, it means after we clicking the close button in the layout view.
1) For the trigger before opening the layout view , i read the below ticket Andrew posted (https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/29819/libmanager-edit-trigger-callback/1335387#1335387).Then i tried to write the code like below:
ddRegTrigger("PreObjAccess" 'layoutpreTrigger)
layoutpreTrigger(@optional libName cellName viewName fileName contexID mode)
  if(libName && cellName && viewName then
    printf("libName:%L cellName:%L viewName:%L mode:%L\n" libName cellName viewName mode)
); ** if **
t
); ** let **
); layoutpreTrigger
It printf " libName cellName viewNae mode " when i tried to open the layout.But it also printf the "libName cellName viewName mode" when i tried to close the layout window.That's not what we need.Is there any place i used wrong here?
2) For the trigger after closing the layout view, i have no good idea as so far.Because sometimes we don't make any change on the layout and we needn't save the layout .So i think "dbRegPostSaveTrigger" should not work well here.Do you have any suggestion?
    Perhaps you should be using deRegUserTriggers instead? Then for the app and postInstall triggers you'll get an action trigger, which would be when you open or close the window, regardless of the access mode.
    There is no "close" trigger at the database level. There's dbRegPurgeTrigger, but that's only when there are enough closes to remove the data from memory - that won't necessarily happen when you close the window because the design may be open elsewhere (e.g. as part of a higher level layout).
