  3. Automatic start point selection for local optimization
  • Subscribers 150
  • Views 11019
FormerMember
FormerMember over 6 years ago
I dont know if I miss something, but I think it is a little cumbersome to run a local optimization. Since it require a starting point, here is what I usually do:
1. Save my current maestro setup (only variables and parameters) to 'Optim'
2. Select all my parameters and do 'Set to design value' to get the current values from the schematics
3. Save another maestro setup 'OptimStart' (also only variables and parameters)
4. Load the 'Optim' to get back the parameter ranges
5. Run a local optimization with 'OptimStart' as starting point
After an optimization run I can save the best result to a setup state and use this as the starting point for the next optimization. However, if I add a new parameter I have to do the above steps again, since the optimizer always complains if it can not find a corresponding value in the starting point setup.
Is it possible to automatize this steps somehow? It is always the same procedure, but I could not find the corresponding skill functions to write a procedure for it and bind it to a menu button. All I want is to tell the local optimization to use the current parameters.
    In IC618/ICADVM181 ISR12 we introduced a new starting point choice on the Local Optimization form; you can now set it to "Automatic" in addition to an existing Setup State. What this does is:
    • For parameters, it retrieves the value from the schematic
    • For global variables, it starts from the midpoint of the optimization range
    So it saves the convoluted process that you describe above (which I agree, was a bit of a pain). Just before ISR12 came out I was talking with a customer about the optimizer and suggested to them that it would be a whole lot easier if we had an option to start from the schematic values, and was about to file a request when I discovered that it had just been implemented. Serendipity at its best!
  • FormerMember
    FormerMember over 6 years ago in reply to Andrew Beckett
    That are good news. I think with the next PDK update we also get to use this new version. Thank you for your answer.
