  3. How to change customVia using skill
  • Replies 10
  • Views 19910
prasadtammana
prasadtammana over 6 years ago
Hi All,
I'd like to replace a customVia with a different customVia. I'm not able to get the parameters of the old customVia using car(geGetSelSet())~>viaHeader~>overrideParams command, as it returns nil.
Could someone help me on how to get the rows and columns information for customVia and also assign these to a new customVia.
Prasad
  • mbracht
    mbracht over 6 years ago
    car(geGetSelSet())~>viaHeader~>viaDef~>params
  • prasadtammana
    prasadtammana over 6 years ago in reply to mbracht
    Thanks for your reply. But it doesn't work. Return nil again.
  • psill000
    psill000 over 6 years ago in reply to prasadtammana
    stdvia
    obj~>cutRows
    obj~>cutColumns
    customVia
    obj~>row
    obj~>column
  • prasadtammana
    prasadtammana over 6 years ago in reply to psill000
    For some reason, even this doesn't work.
  • psill000
    Select the object and type the command below in the CIW
    What does geGetSelSet()~>?? output in the CIW
  • mbracht
    mbracht over 6 years ago in reply to prasadtammana
    sorry - I missed that we talk about a custom via and not a standard via. Custom vias are essentially pcells - can you try this:
    (foreach mapcar param (car (geGetSelSet))~>viaHeader~>master~>parameters~>value (list param~>name param~>value))
    Max
  • prasadtammana
    Sorry ... I'm getting details until car(geGetSelSet())~>viaHeader~>master. nothing after that. It returns nil for parameters.
    Andrew Beckett over 6 years ago in reply to prasadtammana
    Since even for a custom via you would expect that car(geGetSelSet())~>viaHeader~>overrideParams would work, my guess is that your custom via is not actually a parameterised cell and is a fixed layout. The fact that the master doesn't have a parameters hierProp suggests this too.
    If you use Edit Properties on the selected via, does it show any rows/columns or anything like that? Can you change any parameters and do they have an effect?
  • prasadtammana
    prasadtammana over 6 years ago in reply to Andrew Beckett
    Thanks for your reply Andrew. It has rows and columns information in the properties, but they don't have any effect on the layout when changed.
    Another way to check is to find the lib/cell/view of the customVia from the tech file and do:
    cv=dbOpenCellViewByType("lib" "cell" "view")
    if cv~>isParamCell returns nil, it is not a pcell.
    Or you could check:
    car(geGetSelSet())~>viaHeader~>master~>superMaster
    If that is nil, it's not a pcell.
