  3. remove lxInternal attribute from a layout cell view
  • Views 14988
jaleco
jaleco over 6 years ago
I have come across some layout views which contain no devices, and have no corresponding schematic.
However, cv~>lxInternal and cv~>lxInternal~>source are defined with db IDs, and items like cv~>lxInternal~>source~>lib return an empty string, eg "".
Using setq or the equivalent cv~>lxInternal = nil to try to remove the lxInternal attribute results in the values to instead be redefined as "FALSE", which just creates different problems.
eg
then
cv~>lxInternal
will return the value "FALSE"
How do you remove the lxInternal attribute from a layout cell view that has no corresponding schematic view?
  • jaleco
    I have also tried lxSetConfigRef("libname" "cellname" "layout" "NONE") and lxSetConnRef("libname" "cellname" "layout" "NONE"), but the lxInternal attribute and lxInternal~>source etc remain unchanged.
    Latest update - you can remove this attribute - or property - using dbDeletePropByName(cv "lxInternal")
