  3. Menu works on Virtuoso XL but not on EXL
  • Subscribers 150
  • Views 15598
ANSYS
ANSYS over 6 years ago
Hi all,
I'm using a menu to export a cell to a third-party tool that used to work on XL but is no longer working on EXL. Is there anything I could change under cdsinit (or related file) to simply add this menu to EXL version?
Thanks in advance for your help.
  • skillUser
    skillUser over 6 years ago +1
    Hi, There are not enough details, but I imagine that you have a trigger for adding the menu to the layout window? That trigger probably doesn't include the "maskLayoutEXL" view, it probably just uses…
  • skillUser
    There are not enough details, but I imagine that you have a trigger for adding the menu to the layout window? That trigger probably doesn't include the "maskLayoutEXL" view, it probably just uses "maskLayoutXL" - in case you switch between different versions where EXL is not available, check that the viewtype is present in the list returned by deGetAllViewTypes() before trying to register a trigger for it (with deRegUserTriggers() ).
    Best regards,
    Lawrence.
