  3. Schematic net highlighting control
  • Views 20907
CADcasualty
CADcasualty over 6 years ago
In the schematic display options form there are 3 controls for fine tuning net highlighting - Dynamic Highlighting (on/off), Dynamic Net Highlighting (on/off) and Connect by Name Highlighting (on/off). I like the first two to be on but the last one to be off because it's just too visually jarring and disruptive while moving my mouse around. In my .cdsinit I can control the first two using the following commands:
envSetVal("schematic" "symDynamicHilightOn" 'boolean t)
envSetVal("schematic" "schDynamicNetHilightOn" 'boolean t)
however I'm darned if I can find any way to define the last one. Any ideas?
I also saw an earlier post that referenced an envSetVal command that tweaked schDynamicNetHilightNoIslands - I couldn't see that in the documentation. What does that do? Thanks.
  • skillUser
    skillUser over 6 years ago
    I think the setting you need is:
    envSetVal("schematic" "schDynamicNetHilightNoIslands" 'boolean t)
    (or possibly the 'nil' setting?)
    Best regards,
    Lawrence.
  • CADcasualty
    OK - let me be the first to call me a dope. When I tried the schDynamicNetHilightNoIslands command I had it set to nil and was getting all the highlighting lines between the names. I needed to set it to t instead of nil i.e. the on/off aspect of the highlighting is backwards to the other two settings and that threw me. So - never mind...
