  3. Ocean - variable as an input argument of 'axlAddOutputs...
  • Views 3160
Ocean - variable as an input argument of 'axlAddOutputs'
AsafElazari
AsafElazari over 6 years ago
Hi All,
When i try running the two following lines (in my Ocean script):
current_names = list("iref", "vref")
axlAddOutputs(current_names)
i'd get the following error:
*Error* car: argument #1 should be a list (type template = "l") - current_names
Whereas the following line would run with no errors whatsoever:
axlAddOutputs(list("iref", "vref"))
I would like to create the list separately (and only once) in order to use it in different parts of my script.
Does anyone have an idea on how to make those first two lines run? Or maybe another way to approach this that i haven't come up with?
Asaf
    Andrew Beckett over 6 years ago +1
    Hi Asaf, There's an old request for this - CCR 1074271. It's essentially because the OCEAN script is parsed (statically - i.e. without evaluating the code within it) to identify any outputs. So it has…
    Andrew Beckett over 6 years ago in reply to AsafElazari +1
    Hi Asaf, The issue is that the OCEAN script is parsed when you edit it in order to identify the derived outputs to add into the ADE output pane so that you can then put specs on things. It doesn't actually…
    Hi Asaf,
    There's an old request for this - CCR 1074271. It's essentially because the OCEAN script is parsed (statically - i.e. without evaluating the code within it) to identify any outputs. So it has to be a literal list passed in for that reason. I don't think it's vital to add the axlAddOutputs line anyway - if you just have axlOutputResult() lines, then these too are parsed to find the outputs the script produces (these too must use literal names if you want that to work).
  • AsafElazari
    AsafElazari over 6 years ago in reply to Andrew Beckett
    Hi Andrew, Tnx for the quick reply!
    I was trying to avoid those long sections of code containing ' axlOutputResult()'.
    The full code is actually:
      *** code content in which I create a list of waves named 'current_wave_list' ***
     for(i 0 length(current_wave_list)-1 axlOutputResult(average(nth(i current_wave_list)), nth(i current_names)))
    This code runs without errors (even though the inputs of  'axlOutputResult()'  aren't literal) as long as I define the names with ' axlAddOutputs()'  first. I guess that still spares me those long sections of code (because the actual current_names list contains many items), but I still have to define the list twice at the beginning of the code which is a bit messy and tedious.
    Asaf
    Hi Asaf,
    The issue is that the OCEAN script is parsed when you edit it in order to identify the derived outputs to add into the ADE output pane so that you can then put specs on things. It doesn't actually evaluate the code though (which it can't, because no results are available at that time) - so it can only do a static analysis of the code.
    So this is an unfortunate limitation...
