  3. exporting layout into a file (SKILL)
  • Views 14249
Mehrnaz
Mehrnaz over 6 years ago
Hello. I am using virtuoso version ICADV12.3-64b and I need to export the layout of my design into a file so that I can modify the layout using SKILL and then use it for simulation?
I am a beginner in this and all  I know is that the current version of virtuoso does not export the layout into the CIF file. what are my options? which file format can I export from layout? how do I export that?
    You don't need to export the database if you're going to use SKILL to manipulate it - you can do that directly on the database without exporting it to a text format. What kind of modifications are you trying to achieve?
  • Mehrnaz
    Mehrnaz over 6 years ago in reply to Andrew Beckett
    thank you for your quick response.
    There are two kinds of modifications:
    a- I need to widen or move some tiles( wires) in the layout based on calculating the distance between them
    b- I need to modify the pcells in finfet in terms of the fin number
    I am using the finfet library provided by cmc.
    Mehrnaz
    Andrew Beckett over 6 years ago in reply to Mehrnaz
    I would suggest you contact customer support so that we can take a look at some data with you and point you in the right direction.
