  3. Help with rdbWriteToFormat
  • Views 14024
prokie
prokie over 5 years ago
Hello!
I am trying to use the command rdbWriteToFormat to save my output data and later use in matlab. But when I run the script it does not create the file and I am not sure why.
This is my script
simulator( 'spectre )
design( "/home/ponth428/simulation/DAC_TB/spectre/schematic/netlist/netlist")
resultsDir( "/home/ponth428/simulation/DAC_TB/spectre/schematic" )
modelFile(
'("/sw/cadence/libraries/gpdk180_v3.3/models/spectre/gpdk.scs" "stat")
analysis('tran ?stop "$tstop" ?errpreset "conservative" )
desVar( "fclk" 1G )
desVar( "fsin" 0.5M )
desVar( "vdd" 1 )
desVar( "vss" 0 )
desVar( "tstop" "2/fsin" )
envOption(
'analysisOrder list("tran")
temp( 27 )
run()
selectResult( 'tran )
plot(getData("/clk") getData("/sin") getData("/out") )
rdbWriteToFormat( "unbound" "/home/ponth428/output.vcsv" "VCSV" '(("/home/ponth428/simulation/DAC_TB/spectre/schematic/psf" (("tran" ("/out"))))))
    This function only works if you have opened the results browser. Se e How to Export All Signals using rdbWriteToFormat It's not really intended to be a means of exporting to formats (such as VCSV) from…
    This function only works if you have opened the results browser. See  How to Export All Signals using rdbWriteToFormat
    It's not really intended to be a means of exporting to formats (such as VCSV) from OCEAN. I'd suggest you look at the code in this post.
  • prokie
    prokie over 5 years ago in reply to Andrew Beckett
    Okay thanks! Will look in to this! :)
