  3. I just created an object and need to get that database ID...
  • Views 15537
I just created an object and need to get that database ID to use in the next command
Michael Kolesnik
Michael Kolesnik over 5 years ago
Another seemly simple request that I cannot find the easy solution
1. I create a path : leCreatePath(...info...) and it returns a database ID
2. I need to get that ID to use in my next command but don't see how.
You would think that ID is stored in a stack or something.
I could always get it out of the CDS.log file but that seems ridiculous
-Mike
    Hi Mike, What is displayed in the CIW and the CDS.log would not help you anyway - that's just the print representation of a database object (it helps you to see if two objects are the same) - but you…
    Hi Mike,
    What is displayed in the CIW and the CDS.log would not help you anyway - that's just the print representation of a database object (it helps you to see if two objects are the same) - but you cannot start from this print representation and pass it to a function.
    Instead you need to use the return value of the function - either by assigning to a variable, or by nesting the call within another function call. For example:
    cv=geGetEditCellView()
    path=leCreatePath(...info...)
    dbMoveFig(path cv 10:5)
    or:
    dbMoveFig(leCreatePath(...info...) geGetEditCellView() 10:5)
    Essentially the function returns a database object (for which the print representation is db:xxxxxx) - you just need to pass that around to any function that needs it.
