  3. passing the useterms=name option to spectre trough an ocean...
  • Replies 8
  • Subscribers 152
  • Views 6733
passing the useterms=name option to spectre trough an ocean script
ChristophHoehn
ChristophHoehn over 5 years ago
Hi all,
I have the following problem. I want to run my simulations via an ocean script and want to read some currents for some subcircuits out of the psf file later. This all works in principle. The only problem I have is that the currents of subcircuits are stored by pin order rather than pin name by default. I know that I need to change the save option "useterms=name" to get the wanted result. However the ocean function: saveOptions() does not support the 'useterms option. What to do now?
Thanks for your help
    Because this is on the ADE forms anywhere, you have to add this spectre option via the "additional args" field on the Simulator->Options->Analog form, so that corresponds to adding this in your OCEAN script:
    option( 'additionalArgs "useterms=name")
  • ChristophHoehn
    ChristophHoehn over 5 years ago in reply to Andrew Beckett
    thanks for the help. I added the line of code, but I still get the pin order number for the current. What am I missing here?
    Here the code snippet:
    ...simulator, models, etc. ...
    option('additionalArgs "useterms=name")
    saveOption('save "none 'currents "selected")
    save('i "/Imos/Iopffp1")
    run()
    in the results browser I find:
    current: "Imos:4"
    Can you give me a hint here?
    Best Christoph
    Andrew Beckett over 5 years ago in reply to ChristophHoehn
    Christophe,
    The useterms=name only really affects when using currents=all or subcktprobelvl for saving subckt currents. If using selected, and having explicit save statements in the netlist, then the currents are saved under the requested name. Here's what 'spectre -h options" says:
    16      useterms=default  Defines whether device/subckt terminal index (M1:1)
                              or name (M1:d) is saved, when using currents or
                              subcktprobelvl options. Doesn't apply to individual
                              save statements, i.e. save M1:d. default ... save
                              device terminal currents with terminal name and
                              subckt terminal currents with terminal index. index
                              ... save both with terminal index. name ... save both
                              with terminal name. Possible values are default, name
                              and index.
    So check if you have:
    save lmos:4
    in the input.scs.
    If so, you can alter that by changing the spectre simulation information in the CDF for this component. The termMapping will map the symbol terminal name to the model terminal name - and it's probably mapping to :1, :2, ... :4. You can change that to :lopffp1 (for example).
    If that doesn't help, you may need to contact customer support.
  • ChristophHoehn
    I created a file with exactly the save statement you proposed and loaded it into the netlist. When spectre executes it reads the file and saves the results.
    BUT...currents are in pin oder notation...no matter what is in the save statement file.
    However when I use subcktprobelvl option in combination with useterms=name it works. I now save some not needed signals but this is Ok for now.
    What I am still looking for and want to ask for is a comprehensive explenation of all those saving options. How does the logic behind them work? Which options have dependencies on each other? Is there a guide that explains this in detail?
    Best
    Hi Christoph,
    I'm not sure which Spectre version you're using, but for me (with SPECTRE19.1) I found that if the instance is a direct instance of a model, then if I save M1:d or M1:1 I get whichever was saved first. If it's an instance of a subckt and I save both by name or by position, I get both in the output.
    I am not sure about a detailed guide about all the peculiarities of the save statement (I agree, it's a bit hard to fathom at times and can seem a little inconsistent). Perhaps you should contact customer support?
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to ChristophHoehn
    You could take a look at https://community.cadence.com/cadence_blogs_8/b/cic/posts/spectre-tech-tips-spectre-aps-save-overview---part-1 and https://community.cadence.com/cadence_blogs_8/b/cic/posts/spectre-tech-tips-spectre-aps-save-overview---part-2
  • ChristophHoehn
    ChristophHoehn over 5 years ago in reply to Frank Wiedmann
    Thanks Frank I will have a look!
    And best wishes to all I know down in Munich ;-)
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Frank Wiedmann
    And you could also take a look at the Rapid Adoption Kit "Using Spectre SAVE Effectively" at https://support.cadence.com/apex/articleattachmentportal?id=a1O0V00000910oxUAA which has recently been updated.
