  3. hiCreateDisclosureTriangle bold fonts
  • Views 13920
Aldo2
Aldo2 over 5 years ago
Is it possible to set a bold font type for text in "hiCreateDisclosureTriangle", like in "OBJECTS" and "GROUPS" of the attached image?
Thank you
Aldo
    You can use HTML tags around the ?labelText value, as follows (see extraParams below):
    *                   CCFcreateExampleLayForm()                  *
    *               You guessed it. Creates the form               *
    procedure(CCFcreateExampleLayForm()
        let((field1Label field1Entry field2Label field2Entry extraParams
            paramLabel minLabel stepLabel maxLabel
            paramEntry minEntry stepEntry maxEntry
            gridLayout)
            field1Label=hiCreateLabel(
                ?name 'field1Label
                ?labelText "First Field"
                ?justification 'right
            field1Entry=hiCreateStringField(
                ?name 'field1Entry
            field2Label=hiCreateLabel(
                ?name 'field2Label
                ?labelText "Second Field"
            field2Entry=hiCreateStringField(
                ?name 'field2Entry
            extraParams=hiCreateDisclosureTriangle(
                ?name 'extraParams
                ?labelText "<b>Extra Parameters</b>"
                ?onFields
                    list(
                        'paramLabel 'minLabel 'stepLabel 'maxLabel
                        'paramEntry 'minEntry 'stepEntry 'maxEntry
            paramLabel=hiCreateLabel(
                ?name 'paramLabel
                ?labelText "<b>Parameter</b>"
            minLabel=hiCreateLabel(
                ?name 'minLabel
                ?labelText "<b>Minimum</b>"
            stepLabel=hiCreateLabel(
                ?name 'stepLabel
                ?labelText "<b>Step</b>"
            maxLabel=hiCreateLabel(
                ?name 'maxLabel
                ?labelText "<b>Maximum</b>"
            paramEntry=hiCreateStringField(
                ?name 'paramEntry
            minEntry=hiCreateStringField(
                ?name 'minEntry
            stepEntry=hiCreateStringField(
                ?name 'stepEntry
            maxEntry=hiCreateStringField(
                ?name 'maxEntry
            gridLayout=hiCreateGridLayout(
                'gridLayout
                ?items list(
                    list(field1Label 'horiz_align 'right 'row 0 'col 0)
                    list(field1Entry 'horiz_align 'right 'row 0 'col 1 'col_span -1)
                    list(extraParams 'horiz_align 'left 'row 1 'col 0)
                    list(paramLabel 'horiz_align 'left 'row 2 'col 0)
                    list(minLabel 'horiz_align 'left 'row 2 'col 1)
                    list(stepLabel 'horiz_align 'left 'row 2 'col 2)
                    list(maxLabel 'horiz_align 'left 'row 2 'col 3)
                    list(paramEntry 'horiz_align 'left 'row 3 'col 0)
                    list(minEntry 'horiz_align 'left 'row 3 'col 1)
                    list(stepEntry 'horiz_align 'left 'row 3 'col 2)
                    list(maxEntry 'horiz_align 'left 'row 3 'col 3)
                    list(field2Label 'horiz_align 'right 'row 4 'col 0)
                    list(field2Entry 'horiz_align 'right 'row 4 'col 1 'col_span -1)
                    list('col_stretch 0 1)
                    list('col_stretch 1 1)
                    list('col_stretch 2 1)
                    list('col_stretch 3 1)
            hiCreateLayoutForm(
                'CCFexampleLayForm
                "Example Form"
                ; Surrounding vertical box layout is to have a stretchable
                ; item below the layout to absorb all the stretchiness!
                hiCreateVerticalBoxLayout(
                    'vbox
                    ?items list(
                        gridLayout
                        list('stretch_item 1)
            CCFexampleLayForm
    *                  CCFdisplayExampleLayForm()                  *
    *           Create (if needed) and display the form            *
    procedure(CCFdisplayExampleLayForm()
        unless(boundp('CCFexampleLayForm)
        hiDisplayForm(CCFexampleLayForm)
  • Aldo2
    Thank you very much Andrew.
    Best regards
    Aldo
