  3. editing pcell parameter values, having type mismatch
  • Views 13473
malcolm70
malcolm70 over 5 years ago
Hi Cadence -
I created a new pcell and gave it 5 parameter values.  ( param1 thru param5 )
I thought it was going to be easy to feed a new value to the pcell with replaceable text string where I concatenate a string
with a count number:
myPcell = car(selectedSet() )
count=1
while(count< 6
    myPcell~>concat("param" count) = newValue
   count = count +1 )
When I do this I get a *error* getsgq: arguement 2 should be a string or symbol
I've also tried myPcell~>strcat("param" count)   and gotten a similar error.
How can I address the parameter name with replaceable variable names ; is this possible ?
thanks.
    When you use the ~> operator, whatever is to the right is a literal (unevaluated) symbol (or string) and cannot be an expression. You can use:
    get(myPcell concat("param" count) ; to get
    putprop(myPcell newValue concat("param" count)) ; to set
    Or you could use
    prop=dbGetPropByName(myPcell lsprintf("param%d" count))
    prop~>value=newValue
    Or even:
    dbReplaceProp(myPcell lsprintf("param%d" count) "string" newValue) ; if it's a string (change the "string' to the appropriate type)
  • malcolm70
    malcolm70 over 5 years ago in reply to Andrew Beckett
    Thank you Andrew for your help.
