  3. geToggleAreaSelectOption( ) - want to be able to set without...
  • Views 1243
geToggleAreaSelectOption( ) - want to be able to set without cycling
Michael Kolesnik
Michael Kolesnik over 5 years ago
There are 3 selection modes - "enclosed", "crossed", "enclosedAndCrossed"
I want to set the current mode to a variable then set the mode to "enclosedAndCrossed" perform a function then set the mode back to original.
There does not appear to be a way to set it other than cycling thru the choices.
I checked for env settings and there is none that I can see.
    Hi Michael, You can use: hiGetCurrentWindow()~>fullSelectionMode to get the current setting, and use: hiGetCurrentWindow()~>fullSelectionMode="enclosedAndCrossed" (or similar) to set it. So…
    Hi Michael,
    You can use:
    So this way you can change it in the current window the way you want. There is the graphic fullSelectionMode cdsenv var, but that only affects new windows, not existing windows. One a window has been opened, you alter this via window properties instead.
